9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible),
125
0
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | Hi all,
I am in the process of reassembly of my rear hubs on my 1952 2 ton.I was cleaning everything up and noticed the bearing rollers are of an oval shape. Is this correct? It is a Timkin 2 speed rear. The bearings are "Hyatt" brand. Also I am going to replace the gear lube . There is a plug at the front of the 2 speed unit just behind the yoke. If I remove it and refill from this point will the lube flow through and fill the "pumpkin" to the correct level?One more question to you brake experts. When I install the new brake shoes how do you get the correct adjustment. I was told to adjust them until tight against the drums and then back off on turn on the adjusters.Is this correct?
Thanks, JMH | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The bearings could be barrel rollers, as the name implies, they look like a barrel. Fat in the center and skinnier on the ends.
Jeff | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The conical wheel brgs are normal for those. Make sure there are no pits or scoring in them. The replacements are generally straight rollers. If you have to replace one be sure to replace the whole unit. You are supposed to replace both the inner & outer when you change them over. The rear end fills through the plug on the rear cover. Do not desturb the nut & adjuster in back of the yoke. It seems The electric 2 speed drive took 10 weight oil in the bottom, filledthrough a little plug. I don't remember about the vacuum drive. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | Thanks for all the help. Can anyone tell me where I can get a service manual for my 52 2 ton.
JMH | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | manuals available on ebay, thru jim carter and other vendors | | |
