2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#66388 09/29/2006 2:04 AM
Junior Member
Junior Member
hi i am wonder if any one has or knows where i can get longtube headers i have seen a few chevy trucks on line with long tube headers
thankyou
derek
#66389 09/29/2006 2:32 AM
Which engine?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#66390 09/29/2006 3:39 AM
Junior Member
Junior Member
235 ci
#66391 09/29/2006 4:14 AM
http://www.cliffordperformance.net/
used to have long tube headers. On their website, I only see shorty right now. May be worth a phone call.
#66392 10/01/2006 7:04 AM
also what year truck? I have a 230 and the long tube headers wouldn't fit in my 72, but they would fit on my 59 1 ton with a 292. They foul the suspension on the 72, but the 59's straight axle is not in the way (or at least it doesn't look like it will - part of the 59's upgrade once the 72 is did)
#66393 10/01/2006 7:05 AM
and btw, those are cliffords long tube headers. I put shorties on the 72 and it looks like it will be just fine. smile
#66394 10/01/2006 8:01 AM
I don't see why long tube headers would be any better than Fenton cast iron manifolds on a 235. You can't have true tuned length headers on a siamesed port 235 because the exhaust pulses on the siamesed port are asymmetrical. If they are advertised as tuned length, it could only be tuned to the length appropriate to one of the shared cylinders, but not both, on each siamesed port. Do it only if you just like the look, not with the expectation of improved performance.
