| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66388 09/29/2006 2:04 AM | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | hi i am wonder if any one has or knows where i can get longtube headers i have seen a few chevy trucks on line with long tube headers thankyou derek | | |
#66389 09/29/2006 2:32 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | | | |
#66390 09/29/2006 3:39 AM | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | | | |
#66391 09/29/2006 4:14 AM | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | http://www.cliffordperformance.net/ used to have long tube headers. On their website, I only see shorty right now. May be worth a phone call. | | |
#66392 10/01/2006 7:04 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | also what year truck? I have a 230 and the long tube headers wouldn't fit in my 72, but they would fit on my 59 1 ton with a 292. They foul the suspension on the 72, but the 59's straight axle is not in the way (or at least it doesn't look like it will - part of the 59's upgrade once the 72 is did) | | |
#66393 10/01/2006 7:05 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | and btw, those are cliffords long tube headers. I put shorties on the 72 and it looks like it will be just fine.  | | |
#66394 10/01/2006 8:01 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I don't see why long tube headers would be any better than Fenton cast iron manifolds on a 235. You can't have true tuned length headers on a siamesed port 235 because the exhaust pulses on the siamesed port are asymmetrical. If they are advertised as tuned length, it could only be tuned to the length appropriate to one of the shared cylinders, but not both, on each siamesed port. Do it only if you just like the look, not with the expectation of improved performance. | | |
