4 members (Otto Skorzeny, Hotrod Lincoln, Hanks custodian, 1 invisible), 189 guests, and 3 robots.
Topics128,187
Posts1,057,315
Members48,468
Apprentice
Apprentice
My 48 Chevy 1/2 ton has two sets of leaf springs. One set is mounted above the axel and one set is mounted below the axel. Both appear to be original.
All of the trucks and pics of 47-49 trucks that I have seen only have one set.
Have you ever seen this configuration before? Can you explain?
Thanks in advance.
I have parted several trucks in the last few months and a few have had them I believe they were dealer installed I say this because they were not riveted but bolt on assemblies. It was a simple way to increase capacity I guess back in the day.
They were designed to carry additional load in the bed, always called them helper springs, I'm sure someone has a better term. These old trucks were ment to work and carry stuff. I removed mine as I don't intend to haul anything heavy.
1951 restoration on website
http://www.hanklong.com
....my dad and grandad always called them "overload" springs!
