4 members (MickeyP, Ol' Red, jmoore, 1 invisible),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,627 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | I have a 1946 1.5 ton and I'm trying to replace the driveshaft center carrier bearing. The largest replacement one I can find is through Jim Carter Truck Parts and it's for a 3/4 ton. Does anyone know if the 3/4 ton carrier bearing will work for the 1.5 ton truck? If not, where can I track one down? Thanks.
1946 2 Ton Flatbed
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I measured my old one and Jim Carter had one to fit my 1.5 ton 1953,4400.I posted here if anyone had or could give me information on replacing it they responded to take it to my local drive line shop !Well that wasn't what I asked !Its very easy you will just need a press .Good luck | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Does this picture resemble what you have ? bearing support 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | | | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | It's the same as the picture in the link you provided, bowtietim. I guess any 1.5 ton bearing will work from 41-54.
1946 2 Ton Flatbed
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The best way to get a proper bearing is to measure it and then match it to a new one of correct size. I think you find the bearing but the mounting may well be different and require a modification to replace an original style. I'm referring to the older types that mounted to a triangular plate unlike the modern "U" shaped style strap shown in the link above.
If all else fails you can have the midship stub replaced with a current one of correct tube size. A job for a driveline shop but one I've done many times and not difficult for them. | | |
