3 members (78buckshot, Phak1, NJC), 88 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#663273 07/18/2010 3:55 AM
I have a 1946 1.5 ton and I'm trying to replace the driveshaft center carrier bearing. The largest replacement one I can find is through Jim Carter Truck Parts and it's for a 3/4 ton. Does anyone know if the 3/4 ton carrier bearing will work for the 1.5 ton truck? If not, where can I track one down? Thanks.
1946 2 Ton Flatbed
I measured my old one and Jim Carter had one to fit my 1.5 ton 1953,4400.I posted here if anyone had or could give me information on replacing it they responded to take it to my local drive line shop !Well that wasn't what I asked !Its very easy you will just need a press .Good luck
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Does this picture resemble what you have ?
bearing support
1951 3100 Chevrolet
It's the same as the picture in the link you provided, bowtietim. I guess any 1.5 ton bearing will work from 41-54.
1946 2 Ton Flatbed
The best way to get a proper bearing is to measure it and then match it to a new one of correct size. I think you find the bearing but the mounting may well be different and require a modification to replace an original style. I'm referring to the older types that mounted to a triangular plate unlike the modern "U" shaped style strap shown in the link above.
If all else fails you can have the midship stub replaced with a current one of correct tube size. A job for a driveline shop but one I've done many times and not difficult for them.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
