2 members (delky, dt235sd),
43
Mod | | | Forums66 Topics128,179 Posts1,057,157 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I have a 66 Suburban that I will probably have to replace the gas tank, rather than cleaning and sealing. I have seen the repops for the pickups to relocate from inside, but is there anyone out there that sells the original style suburban tank? Mine has a half moon in it for spare tire clearance, and I don't see this on the repops. Thank you for your help. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | You have a suburban,so your in the right forum.I did a little searching and came up with nothing.Maybe some one here will know where you can find one.Good luck !!
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Put it in the 60-66..ALSO, not instead of. Don't throw away your orig yet!! May not be a better choice. Someone will be parting one out near you someday. Keep checking your craigslist and ebay. Good luck. Also would a panel truck have the same one?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | If you find a source I am in the market as well. I have done several searchs with no luck. If I find some I will tell the stovebolt world. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....for what its worth. I couldn't get a repop for my 52 panel until about a year ago when JimCarter started having them remade. It may be worth a phone call to see if he by change has one. JimCarter also has some used stuff and may have a good tank in the back yard. Its worth a call.
I might add that the repop tank he is doing for my 52 Panel is "dead on" and is good quality. (Thanks JimCarter) | | | | | Joined: Dec 2006 Posts: 11 New Guy | | New Guy Joined: Dec 2006 Posts: 11 | I got a new tank for my 65 a couple years ago from a gas tank place online. It was an 80s Blazer tank and went in fairly painlessly. I did put in a new sender also and the guage works, but is about 80% accurate (better than nuthin).
Lead, follow, or get outa the way. 50 Chevy 5 window, 65 chevy panel
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Fellas Just to enlighten, The gas tanks on 60-66 burbs and panels ARE Different. 60 thru 62 trucks had wider frame rails in the rear than 63 thru 66 because of the torsion bar front suspension and X frame design. Try putting a 65 bumper on a 62. It wont fit,The bolt holes are like 4" wider. Tried to put a 62 chev sub tank in a 65 panel,NO GO Tank TOO Wide,Trust me. regards Steve Sr | | |
