6 members (Dennys28, baldeagle, 39Master85, Hotrod Lincoln, Otto Skorzeny, dt235sd), 68 guests, and 3 robots.
Topics128,180
Posts1,057,149
Members48,464
I have a 66 Suburban that I will probably have to replace the gas tank, rather than cleaning and sealing. I have seen the repops for the pickups to relocate from inside, but is there anyone out there that sells the original style suburban tank? Mine has a half moon in it for spare tire clearance, and I don't see this on the repops.
Thank you for your help.
Sir Searchalot
Sir Searchalot
Put this in 60-66 Forum.
You have a suburban,so your in the right forum.I did a little searching and came up with nothing.Maybe some one here will know where you can find one.Good luck !!
1951 3100 Chevrolet
Sir Searchalot
Sir Searchalot
Put it in the 60-66..ALSO, not instead of. Don't throw away your orig yet!! May not be a better choice. Someone will be parting one out near you someday. Keep checking your craigslist and ebay.
Good luck. Also would a panel truck have the same one?
If you find a source I am in the market as well. I have done several searchs with no luck. If I find some I will tell the stovebolt world.
....for what its worth. I couldn't get a repop for my 52 panel until about a year ago when JimCarter started having them remade. It may be worth a phone call to see if he by change has one. JimCarter also has some used stuff and may have a good tank in the back yard. Its worth a call.
I might add that the repop tank he is doing for my 52 Panel is "dead on" and is good quality. (Thanks JimCarter)
I got a new tank for my 65 a couple years ago from a gas tank place online. It was an 80s Blazer tank and went in fairly painlessly. I did put in a new sender also and the guage works, but is about 80% accurate (better than nuthin).
Lead, follow, or get outa the way. 50 Chevy 5 window, 65 chevy panel
Fellas
Just to enlighten,
The gas tanks on 60-66 burbs and panels ARE Different.
60 thru 62 trucks had wider frame rails in the rear than 63 thru 66
because of the torsion bar front suspension and X frame design.
Try putting a 65 bumper on a 62.
It wont fit,The bolt holes are like 4" wider.
Tried to put a 62 chev sub tank in a 65 panel,NO GO
Tank TOO Wide,Trust me.
regards Steve Sr
