| | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | I used to have a 64 chevy c-10 350/350 automatic. But now I maybe getting a 64 c-20 it has a 350 with a standard trans not sure what size. But I wanted to put a 350 auto in it but how would the rear end handle it? Would I be better off swapping for another rear end? If so what year and make would fit right in there without any welding or cutting? Could i have 8 lugs up front and 6 lugs or 5 lugs in rear with no problems?
Stovebolt-It is painted
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | You more than likely have an Eaton HO52 you won't destroy it time with a TH350. Your biggest problem is the rear axle ratio, it is probably 4.56 or higher. The best gear ratio you might find is 4.10. I would look at putting a 700R4 in it. The 700R4 overdrive would get your highway rpm down to 2200-2400.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Forget about the C20. Find a C10. Especially in California where you've gotta take a freeway to get any and everywhere. It's just too much hassle plain and simple. Parts are much easier to come by for the 1/2 ton. There's stuff for the C20 that you just can't get. And if you can, it's more expensive. If it's just a truck to drive, find a C10. If you want a truck that looks cool AND for hauling capacity, then yeah a C20 with 700R4 will do you just fine. | | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | Yep you right brotha. Doesn't look like I want the c-20 after all. I been making deals and am getting rid of my 50 buick roadmaster project for a 61 c-10 longbed fleet. Been wanting an apache for a long time now. Still got me my 51 pontiac chief so that will be kinda cool to see a apache and chieftain next to each other. Thanks for the advice guys.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Just watch out they don't scalp each other. | | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | I have not heard from the guy with c-20 or the other guy with the 61 c-10 so my search continues
