0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 31 Apprentice | | Apprentice Joined: Dec 2003 Posts: 31 | Jacked up the truck today to work on the starter and it wasn't too fun. I'd like to buy some ramps. Anyone know the weight of a 1950 truck? I have a 454 (figure that's 650lbs there). I'm thinking the Rhino 12000 ramps look good.
I too have a starter issue when hot. Not sure if it's the battery or lack of a heat shield. Going to investigate further and having some ramps should make things easier on me.
Steve | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Ramps are OK, but hard to use on concrete. You get about half way up and they sometimes go shooting across the garage. I would invest in a good quality floor jack and jack stands instead. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I have a lot of info on starter problems. P.m. me for the long story. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Ramps are OK, but hard to use on concrete. You get about half way up and they sometimes go shooting across the garage. I would invest in a good quality floor jack and jack stands instead. Rhinoramps have rubber feet on them to stop them from sliding around. I have put my daily driver on them plenty of times and they have never moved. | | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | I bolt my ramps down to a couple of pieces of 2 X 12 lumber about 4 feet long. It gives an extra 1 1/2" of lift, and stops the slide very effectively. Jerry
| | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Google them or check Amazon for the product load capacity. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Try and get the ones that the ramp part comes off for better access.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I made ramps out of 3/4" plywood and yes they do scoot. I lay down a couple of 8 ft, 2x4's between the ramps and the rear wall foundation curb. There are several braces and cross braces, cleated, glued and screwed together on the inside. I made them originally for the Vette because the ones that were available were either super long or if shorter and stepped, the lower part of the ramp was not removable. We b OLD, I have never seen any, other than mine that came apart. I have pictures posted on a Corvair forum so I thought I would show you those. two piece stepped ramps I have had a number of different car weights on them including the Dodge magnum RT with HEMI. 4200 lbs. My 3/4 GMC sits high enough that it was only on the top of the ramp to test them. I often just use the lower part of the ramp by itself for many tasks on a variety of cars. The steel rod laying on the ground, slides through a hole and locks the two sections together.
'67 GMC 3/4 292 4spd
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Your truck should weigh about 3,500 pounds, give or take. I have a similar vintage. Regular car ramps will work just fine.
And your big block Chevy actually weighs almost exactly the same as a stovebolt 6 does, maybe even 20 lbs lighter than the stovebolt...believe it or not. So you really aren't any heavier than a stock truck.
Now, my all-iron 350 weighs about 120 pounds less than a stovebolt engine, so my weight would come in at about 3380 lbs. It's a good motor, but I'll bet it doesn't feel near as nice as your 454! | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I put pins in my ramps into holes in the concrete
