| | | Forums66 Topics128,288 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66136 09/21/2006 12:43 AM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | I want to put a 350 turbo behind my 56 Chevy 6 cyl. what do I have to do??? The bolt pattern is different!Adaptor plate? Who makes them? Thanks for any help.  | | |
#66137 09/21/2006 2:51 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | I am not the expert but I do know that you need a adapter to adapt a 235 to a Turbo350 I have also herd that some of the adapter plates were not as strong as compeating brands,? hopefully some one will come along to enlighten the subject. | | |
#66138 09/21/2006 5:53 PM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | Buffalo Enterprises, Arlington, Washington. Phone 360-652-7684. And Langdon's Stovebolt, www.stoveboltengineco.com 586-739-9601 both sell the adapter plate you need. | | |
#66139 09/23/2006 5:20 PM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | | | |
#66140 09/24/2006 2:13 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | GM offered the powerglide behind 235's and used a cast iron adapter. Since the PG and 350 bolt up the same it's all factory stuff. We usually found them in 60-62 cars since more people were starting to order automatics by then. You will have to fab a rear mount.
Evan
#66141 09/25/2006 6:29 PM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | Hey Coilover. Will the earlier powerglide adapter (1953) bolt to a 350 turbo transmission or is it different on the transmission side? | | |
#66142 09/26/2006 12:42 AM | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy guys, the factory adapter to put the powerglide behind the 235/261 will not allow anything but that model powerglide to be installed, that model powerglide has a shorter bellhousing [to allow for the adapter] which has a different bolt pattern. Hope that helps. | | |
#66143 09/26/2006 1:20 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's what I was thinking, too. There were 2 different adapters for the early Powerglide, 1 for the 6 and 1 for the 8. It's most definetly not the same as the later Hydromatics.
Bill Burmeister | | |
