Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (tclederman, Bill Hanlon, Phak1), 178 guests, and 5 robots.
Topics128,288
Posts1,058,566
Members48,492
#66136 09/21/2006 12:43 AM
I want to put a 350 turbo behind my 56 Chevy 6 cyl. what do I have to do??? The bolt pattern is different!Adaptor plate? Who makes them? Thanks for any help. smile
I am not the expert
but I do know that you need a adapter to adapt a 235 to a Turbo350
I have also herd that some of the adapter plates were not as strong as compeating brands,?
hopefully some one will come along to enlighten the subject.
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
Buffalo Enterprises, Arlington, Washington. Phone 360-652-7684. And Langdon's Stovebolt, www.stoveboltengineco.com
586-739-9601 both sell the adapter plate you need.
A 1965 Chevy C-60 2-Ton Flatbed
A 1953 Chevy 1/2-Ton
A 1949 Chevy Business Coupe
Thanks for the help !!
GM offered the powerglide behind 235's and used a cast iron adapter. Since the PG and 350 bolt up the same it's all factory stuff. We usually found them in 60-62 cars since more people were starting to order automatics by then. You will have to fab a rear mount.
Evan
Hey Coilover. Will the earlier powerglide adapter (1953) bolt to a 350 turbo transmission or is it different on the transmission side?
3B Offline
Hy guys, the factory adapter to put the powerglide behind the 235/261 will not allow anything but that model powerglide to be installed, that model powerglide has a shorter bellhousing [to allow for the adapter] which has a different bolt pattern. Hope that helps.
That's what I was thinking, too. There were 2 different adapters for the early Powerglide, 1 for the 6 and 1 for the 8. It's most definetly not the same as the later Hydromatics.
Bill Burmeister
