| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | Received my order from JC, and opened the cab mount kit. It contained 8 bushings, two rubber squares with matching steel plates, 2 cupped round disks, and 2 bolts. Question - since none of these existed when I got the truck, where and how do they go. I am assuming the square rubber and steel go on the back shackles, not sure about the bushings, and assume the cupped stamped disks go in the front somhow, not sure how or where. Also I am not sure why only two bolts,and why is there nothing for damping up front? Thanks in advance for any help. Mike My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man! 1953 Chevy 3100 Shortbed1965 C-30 Panel Truck 1963 C-20 Long/Fleet Pick-up California Black Plate
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | This is how it assembles: The round rubber bushings go in the rear mounts 4 in each one. You can see a completed refurbishment of one here (painted red because I like it factory are usually black under the undercoat). http://community.webshots.com/photo/2275285170102454676BEQvTZhttp://good-times.webshots.com/photo/2235943390102454676FUuGUvThe piece with the bolts goes through the rubber then you put on the additional plate and tighten so they compress a bit. There are no rubber pads here some trucks are shimmed with small thin metal shims on either the frame or the cab side. The thicker metal threaded piece goes inside the cab behind the seat pan. The two rubber squares go in the front between the cab and the mount on the frame, the steel pieces go under the frame mount where the nut and washer tighten, the cupped piece goes on your cab floor and the bolt goes through it. You should really consider buying a Factory Assembly Manual for these trucks that most vendors sell since it has good views of these items. | | | | | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | Brad, Thanks, I find the assembly manual confusing at times. I now know that I have bushings for the shackles, and the rest of the hardware goes to the front mounts. I don't have the plates you show in your photos, either threaded holes or through holes. Would it be possible to give me the thickness of those plates and the bolt lengths, I assume the length and width of the plates corresponds to the shackle. I can have the shop at work make something up for them. Thanks, Mike My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man! 1953 Chevy 3100 Shortbed1965 C-30 Panel Truck 1963 C-20 Long/Fleet Pick-up California Black Plate
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Yes I will measure them up tonight and get the details to you on Monday. They are best to use for the cab mounts because depending on strain washers and nuts can pull through the floor. The shims are just for leveling the cab if neccessary at the factory based on measurements but you may find you need them so I will measure everything up. | | | | | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man! 1953 Chevy 3100 Shortbed1965 C-30 Panel Truck 1963 C-20 Long/Fleet Pick-up California Black Plate
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Ok here are the numbers for you:
Cab locking plates are 1/4" thick by 1" x 2-1/4" they are threaded for 3/8" NC bolts which are 1-1/2" long the holes are 1/2" in from the edge on the long-side. The shims are 1-3/4" x 2-1/4" with the holes the same from the long-side they are 15ga material but anything close would work. The bolts that hold the bracket to the frame are 1-1/4" long 3/8" NC. Hope that helps. | | | | | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | Brad, Thank you very much! Now out to the shop to scavenge material, and time on the Bridgeport. Mike My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man! 1953 Chevy 3100 Shortbed1965 C-30 Panel Truck 1963 C-20 Long/Fleet Pick-up California Black Plate
