1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#660694 07/08/2010 12:56 PM
Hi All,
I am currently working on removing the head on my 1954 Chevrolet 3100. I have everything stripped down and ready to go, however i am unsure as to whether or not there is a specific pattern in which the bolts need to be removed? Any Ideas? Thanks
I don't know a specific pattern for removal, but one for installation. You can always do the reverse if you're not sure.
Drew
DrewP #660729 07/08/2010 3:59 PM
I've managed to get the head off, could you please tell me the installation pattern? Thanks
Torque spec is 90-95 foot pounds. The installation pattern is from the center outward in a clockwise pattern. It would be a good idea to torque them in two or three steps 30 lb. 60 lb. 90 lb.
Here is a piucture.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Best thing to do is get a repair manual for You're truck all that info is there and that way You can have it right in front of You as You're working on what ever project You're doing at the time ,less likly to make mistakes and don't need to wonder if You remember right or not.
Pete
Pete52 #660769 07/08/2010 6:49 PM
HERE is the sequence, scroll down to the 18-bolt information. Info supplied via fellow bolter tclederman.
When my head is finished at the machine shop next week, I plan on using the method outlined by T'mater, that's the way I also have done them. If it even looks like one of them is twisting or in poor shape, buy a set of headbolts.
Hank
1951 restoration on website
http://www.hanklong.com
Hankdogg #660880 07/09/2010 2:08 AM
Thanks!
Well, good luck finding new ones. They were like hens teeth when I was looking for them. Hopfully someone is now making them.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
