0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 22 New Guy | | New Guy Joined: Jan 2009 Posts: 22 | Hi All,
I am currently working on removing the head on my 1954 Chevrolet 3100. I have everything stripped down and ready to go, however i am unsure as to whether or not there is a specific pattern in which the bolts need to be removed? Any Ideas? Thanks | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I don't know a specific pattern for removal, but one for installation. You can always do the reverse if you're not sure.
Drew
| | | | | Joined: Jan 2009 Posts: 22 New Guy | | New Guy Joined: Jan 2009 Posts: 22 | I've managed to get the head off, could you please tell me the installation pattern? Thanks | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Torque spec is 90-95 foot pounds. The installation pattern is from the center outward in a clockwise pattern. It would be a good idea to torque them in two or three steps 30 lb. 60 lb. 90 lb. Here is a piucture. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Best thing to do is get a repair manual for You're truck all that info is there and that way You can have it right in front of You as You're working on what ever project You're doing at the time ,less likly to make mistakes and don't need to wonder if You remember right or not.
Pete | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | HERE is the sequence, scroll down to the 18-bolt information. Info supplied via fellow bolter tclederman. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | When my head is finished at the machine shop next week, I plan on using the method outlined by T'mater, that's the way I also have done them. If it even looks like one of them is twisting or in poor shape, buy a set of headbolts.
Hank | | | | | Joined: Jan 2009 Posts: 22 New Guy | | New Guy Joined: Jan 2009 Posts: 22 | | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Well, good luck finding new ones. They were like hens teeth when I was looking for them. Hopfully someone is now making them. | | |
