| | | Forums66 Topics128,018 Posts1,055,341 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 17 New Guy | | New Guy Joined: Jun 2010 Posts: 17 | Hi all I have a question, I live about 2 hours west of Ottawa, and we have pretty nasty winters. I may be able to store it in an unheated garage for the winter, however if not, what is the best way to store my 64 for the winter? I am not worried about the paint at this time as it is all getting redone and there is no motor, fittings, etc... but I would like to learn the best way from you knowledged folk (to prevent major rusting)! Thank you! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..I don't think MAJOR rusting will take place over one winter, especially if you can keep it covered and dry. Someone else may have a better suggestion but I'd set it on blocks, so the floorpans are not so close to the ground and air movement can get under it...and keep it covered with a decent tarp. Just depends on your $$ but this is only for ONE winter!! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | We're not quite as bad here,except for last winter!
I agree with Alvin, a well fitted tarp, but one that will allow some airflow under would be good.
The main problem I experienced with mine was paint chaffing when the winds got going. Shouldn't be a major rust problem as you'll be painting it anyway. My main concern would be condensation in the interior,you don't want mould forming on your seat etc. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2010 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 119 | Place a can or two of silica absorber in the cab for moisture removal. | | | | | Joined: Jun 2010 Posts: 17 New Guy | | New Guy Joined: Jun 2010 Posts: 17 | All you guys are so helpful! Thanks for the great tips- I will do all of those things  | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I suggest putting plactic under the vehicle to prevent moisture from coming up from the ground. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | ..Someone else may have a better suggestion but I'd set it on blocks Now Alvin, there you go giving away our state secret of sitting vehicles up on blocks around in the yard. Look close and you'll see an old Ferd Pinto on blocks under the Palmetto tree on our state seal.  | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | Dont go givin' away ar secrets!
You ent one dem cappetbaggahs, is ya? | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | | | |
