0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#660497 07/07/2010 10:32 PM
I
I Offline
Hi all smile
I have a question, I live about 2 hours west of Ottawa, and we have pretty nasty winters.
I may be able to store it in an unheated garage for the winter, however if not, what is the best way to store my 64 for the winter?
I am not worried about the paint at this time as it is all getting redone and there is no motor, fittings, etc... but I would like to learn the best way from you knowledged folk (to prevent major rusting)!
Thank you!
..I don't think MAJOR rusting will take place over one winter, especially if you can keep it covered and dry. Someone else may have a better suggestion but I'd set it on blocks, so the floorpans are not so close to the ground and air movement can get under it...and keep it covered with a decent tarp. Just depends on your $$ but this is only for ONE winter!!
We're not quite as bad here,except for last winter!
I agree with Alvin, a well fitted tarp, but one that will allow some airflow under would be good.
The main problem I experienced with mine was paint chaffing when the winds got going.
Shouldn't be a major rust problem as you'll be painting it anyway.
My main concern would be condensation in the interior,you don't want mould forming on your seat etc.
More pix on Flickr.
Place a can or two of silica absorber in the cab for moisture removal.
I
I Offline
All you guys are so helpful! Thanks for the great tips- I will do all of those things
grin
I suggest putting plactic under the vehicle to prevent moisture from coming up from the ground.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
..Someone else may have a better suggestion but I'd set it on blocks
Now Alvin, there you go giving away our state secret of sitting vehicles up on blocks around in the yard. Look close and you'll see an old Ferd Pinto on blocks under the Palmetto tree on our state seal. smile
1951 restoration on website
http://www.hanklong.com
Hankdogg #661358 07/10/2010 10:39 PM
Dont go givin' away ar secrets!
You ent one dem cappetbaggahs, is ya?
Naw, he's a native.
