4 members (sron48, BC59, 2 invisible), 133 guests, and 5 robots.
Topics128,086
Posts1,056,099
Members48,434
#657947 06/28/2010 2:49 AM
$100.000 question.O n the rear of the front fender 1/2 ton chev truck above the running boards stock metal truck along the cab their is a gap. Does a special rubber go their. Above the running board fender mount are three small holes.the gap is approx 1/4 inch wide.If it does take a seal does it exsist. thanks peter
peter foster
pierce #657981 06/28/2010 4:46 AM
pierce-
I've got a fairly stock 1937 Chevy 1/2 ton pickup and I have never found the correct piece for that spot. I have been told it is a piece of windlace type material covered in a vinyl or leather of a color that would go with your truck, probably black. I had my upholstery guy make two for me. Basically they look like large pieces of fender welt. They do work good and look good, but I'm not sure if they are correct. I think the 38 truck has the same situation.
I'd like to know if you come up with some more solid information on this question.
Joe
Joe thanks for the heads up on this.I have also contacted debra who also has a 1937. so that makes three of us so far.How about you other guys and gals at stovebolt.com DO YOU HAVE A ANSWER.or a pattern we could follow thanks peter
peter foster
pierce #657987 06/28/2010 5:42 AM
This is a new one on me... I don't ever recall seeing a gap there... unfortunately my truck is not here right now so I can't go look but to the best of my recollection the right front fender fits the same as the left front with no gaps or holes...
My 1939 1/2 has the same gap.
K9sicem #658172 06/28/2010 11:02 PM
I have a gap but when you put on fiberglass fenders you can make them fit a little tighter smile.... Thanks for your input Joe. I think I'll put that info right up there with the elusive "diamond series" I read about once and we discussed some.
A-h-h-h, yes! The elusive "Diamond Series"! I remember that discussion well!
When I bought my '37 it was already in pieces so it's all been a puzzle to me! I figured that I would just scratch-build the welting.
Everything is different now...
