0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 16 New Guy | | New Guy Joined: Dec 2009 Posts: 16 | $100.000 question.O n the rear of the front fender 1/2 ton chev truck above the running boards stock metal truck along the cab their is a gap. Does a special rubber go their. Above the running board fender mount are three small holes.the gap is approx 1/4 inch wide.If it does take a seal does it exsist. thanks peter
peter foster
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | pierce- I've got a fairly stock 1937 Chevy 1/2 ton pickup and I have never found the correct piece for that spot. I have been told it is a piece of windlace type material covered in a vinyl or leather of a color that would go with your truck, probably black. I had my upholstery guy make two for me. Basically they look like large pieces of fender welt. They do work good and look good, but I'm not sure if they are correct. I think the 38 truck has the same situation. I'd like to know if you come up with some more solid information on this question. Thanks, Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2009 Posts: 16 New Guy | | New Guy Joined: Dec 2009 Posts: 16 | Joe thanks for the heads up on this.I have also contacted debra who also has a 1937. so that makes three of us so far.How about you other guys and gals at stovebolt.com DO YOU HAVE A ANSWER.or a pattern we could follow thanks peter
peter foster
| | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | This is a new one on me... I don't ever recall seeing a gap there... unfortunately my truck is not here right now so I can't go look but to the best of my recollection the right front fender fits the same as the left front with no gaps or holes...
| | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | My 1939 1/2 has the same gap. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have a gap but when you put on fiberglass fenders you can make them fit a little tighter  .... Thanks for your input Joe. I think I'll put that info right up there with the elusive "diamond series" I read about once and we discussed some. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | A-h-h-h, yes! The elusive "Diamond Series"! I remember that discussion well!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 113 | When I bought my '37 it was already in pieces so it's all been a puzzle to me! I figured that I would just scratch-build the welting.
Everything is different now...
