2 members (Hush, delky),
141
0
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 21 | Curious if the middle seat for the 1960 Suburban is the same through years 1960 to 1966? Welcome advice and any knowledge on this subject. THANKS | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'd also like to see pictures. I suspect the rear seat in my '54 is from a '60-66. I'd like to compare. Thanks. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The middle seat is suppose to be the same from 1960-1966 according to Jim carter,are you needing one ? It has a metal tube arm rest on one side.
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | The middle seat for the 60-66 Suburban are the Same, Except the mounting holes to bolt them down are drilled in different spots. | | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | correction, the 1960-66 Chevy middle seat are all the same except the mounting holes. the 1960-62 are the same as chevy, but the 63-66 GMC's have the flat brackets for mounting the seat on the slider rails. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I was hoping someone could tell me if mine is indeed a '60-66 middle seat. It looks to me to be a mate to the back seat I have that RJ has identified as '60-66 Chevy. rear seat 1 rear seat 2 | | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | | | | | | Joined: May 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 35 | Your red seat looks like a rear seat but in the middle. There were no mounts in the middle for a full size seat. Just a 3/4 seat. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, it is a rear seat mounted in the middle position. It does not mount properly in either position in the '54. It is mounted to 2X12s which are bolted to the floor.
On '47-59 Suburbans the rear seat will properly mount in the middle position. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | yes Cletis your seat is 1960-1966 . 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | My '62 has two sets of key-hole mounting plates in the floor--one for the short middle row seat, and one for the full-width rear seat. My full width seat mounts in the middle just fine. The guy I bought my truck from had a '61 Suburban, and didn't realize he had the same arraingement until AFTER he sold me the truck and the "spare" full-width rear seat he had for an extra $100. He said "You can probably cut this one down to fit in the middle." I said "I think it'll fit as-is----here, watch..." and bolted it in place. He was sick when he realized it! He needed a full-width one for the middle of his '61, but was making due with the short one.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | |
