1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 3 New Guy | | New Guy Joined: Jun 2010 Posts: 3 | anybody know what the small gearbox attached to the speedo cable under the dash of my gmc is for?it has a vacuum line attached to a diaphragm and it looks to control the speedo but i dunno what its for. | | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | It's for the 2 speed rear. It shifts when the rear shifts so the speedometer is correct. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | Anyone know where to find a new 1 | | | | | Joined: Jun 2010 Posts: 3 New Guy | | New Guy Joined: Jun 2010 Posts: 3 | well the gears and shift lever works but the diaphragm is busted so it wont shift so i just ran it to the upper side and it seems to work ok when the axle is in the high side.but i would like to repair it so it works properly but havent found any parts as of yet | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The vacuum became obsolete in the mid 60's. Ever once in a while the adapters appear on eBay, but I don't know if they are any good either. Electric has been available since the 50's was used many years. I have a vacuum and don't worry about. It would be possible to wire a micro switch in to operate an electric adapter. | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | It does depend on the distance the mechanism needs to travel, but I've repaired similar items with a chunk of bicycle inner tube cut to fit. If it's too thick for that unit there are other items available that can be used for material, various types of chemical gloves come to mind. There are also rubberized fabrics available that are a bit harder to get the fit right, but are more durable over time. Not meant to be permanent fixes, but may get you operational until replacements can be located. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Ten years ago I bought a new diaphram for my 1956 2-speed from my local BIG GMC Truck Dealer...have you tried them? Mike B  | | | | | Joined: Dec 2009 Posts: 24 New Guy | | New Guy Joined: Dec 2009 Posts: 24 | Ten years ago I bought a new diaphram for my 1956 2-speed from my local BIG GMC Truck Dealer...have you tried them? Mike B  The scary part about that is that they don't make big GM trucks any more. I guess the dealers who previously sold them will still service them and handle parts, but I think the Medium Duty Truck business was sold to Isuzu or someone. | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | As long as there is a part number, and if it is still available, any GM dealer can get it for you. That part # should be listed in the 46-72 Medium Duty Truck Parts Catalog.
| | | | | Joined: Jun 2010 Posts: 3 New Guy | | New Guy Joined: Jun 2010 Posts: 3 | ok thanks for the input folks greatly appreicated on this end | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I found a vacuum actuator from an eighties carburetor that was close in size and fabricated a mount for it work great on my 56. Just another idea.
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | I have made antique outboard motor fuel pump diaphragms out of rubberized gasket material. Check with any industrial rubber and gasket supplier, and they should be able to point you in the right direction. I've been given scraps of thin rubber gasket material big enough to make dozens of small diaphragms from these places. Jerry
