2 members (Guitplayer, Achipmunk), 61 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#653322 06/08/2010 8:53 PM
U
U Offline
anybody know what the small gearbox attached to the speedo cable under the dash of my gmc is for?it has a vacuum line attached to a diaphragm and it looks to control the speedo but i dunno what its for.
It's for the 2 speed rear. It shifts when the rear shifts so the speedometer is correct.
Anyone know where to find a new 1
joek3167 #653518 06/09/2010 3:04 PM
U
U Offline
well the gears and shift lever works but the diaphragm is busted so it wont shift so i just ran it to the upper side and it seems to work ok when the axle is in the high side.but i would like to repair it so it works properly but havent found any parts as of yet
The vacuum became obsolete in the mid 60's. Ever once in a while the adapters appear on eBay, but I don't know if they are any good either. Electric has been available since the 50's was used many years. I have a vacuum and don't worry about. It would be possible to wire a micro switch in to operate an electric adapter.
crenwelge #653641 06/10/2010 1:16 AM
It does depend on the distance the mechanism needs to travel, but I've repaired similar items with a chunk of bicycle inner tube cut to fit. If it's too thick for that unit there are other items available that can be used for material, various types of chemical gloves come to mind. There are also rubberized fabrics available that are a bit harder to get the fit right, but are more durable over time.
Not meant to be permanent fixes, but may get you operational until replacements can be located.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Freq2002 #653672 06/10/2010 2:42 AM
Ten years ago I bought a new diaphram for my 1956 2-speed from my local BIG GMC Truck Dealer...have you tried them?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #653964 06/11/2010 11:03 AM
Mike B smile
The scary part about that is that they don't make big GM trucks any more. I guess the dealers who previously sold them will still service them and handle parts, but I think the Medium Duty Truck business was sold to Isuzu or someone.
1970 Chevy C10 Short Box
[http://www.stovebolt.com/gallery/price_ben_1959.html]1959 Chevy C-60 Dump Truck[/url]
More pix in Photobucket
bullittben #653971 06/11/2010 1:25 PM
As long as there is a part number, and if it is still available,
any GM dealer can get it for you.
That part # should be listed in the 46-72 Medium Duty Truck Parts Catalog.
JeffL #654152 06/12/2010 2:37 AM
U
U Offline
ok thanks for the input folks greatly appreicated on this end
Unity Truck #654357 06/13/2010 12:51 AM
I found a vacuum actuator from an eighties carburetor that was close in size and fabricated a mount for it work great on my 56. Just another idea.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
I have made antique outboard motor fuel pump diaphragms out of rubberized gasket material. Check with any industrial rubber and gasket supplier, and they should be able to point you in the right direction. I've been given scraps of thin rubber gasket material big enough to make dozens of small diaphragms from these places.
