| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | thought this might be worth a shot....I have a 49 chevy 1/2 with a 350 sbc I'm using a recored stock radiator and a long water pump...anybody running something pretty much the same that would know some part#s for upper and lower radiators hoses ?...thanks.....dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Dave, I went to the chrome flex tube. You can bend it where you want it and hacksaw off as much is needed. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I did the same as gazim, David, worked well for me! | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I measured mine using a piece of wire to get the length, then went to local parts store and purchased corrugated rubber hoses. Seem to work fine - no flow or overheating issues. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The top is the easiest. For the bottom....a friend of mine was building a rat rod and I happened to be in Advance Auto when he bought the bottom hose. I told him to save me the half he didn't use...... well, he did and it ended up being the right thing. I cut it off some but it worked good. So, I used one end of a hose Dayco # 71727. I guess I got lucky. For the top hose you just need to measure length, go to parts house and look for a flex/corrugated hose that has the right size ends on it. That one is the easy one! | | |
