3 members (KCMongo, HelmutVonSchet, 59 fleet), 90 guests, and 0 robots.
Topics128,049
Posts1,055,679
#653753 06/10/2010 1:08 PM
thought this might be worth a shot....I have a 49 chevy 1/2 with a 350 sbc I'm using a recored stock radiator and a long water pump...anybody running something pretty much the same that would know some part#s for upper and lower radiators hoses ?...thanks.....dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Dave, I went to the chrome flex tube. You can bend it where you want it and hacksaw off as much is needed.
gazim #653782 06/10/2010 3:48 PM
I did the same as gazim, David, worked well for me!
I measured mine using a piece of wire to get the length, then went to local parts store and purchased corrugated rubber hoses. Seem to work fine - no flow or overheating issues.
1940 Chevy KC 1/2-Ton
Britcon #653932 06/11/2010 4:02 AM
The top is the easiest. For the bottom....a friend of mine was building a rat rod and I happened to be in Advance Auto when he bought the bottom hose. I told him to save me the half he didn't use...... well, he did and it ended up being the right thing. I cut it off some but it worked good. So, I used one end of a hose Dayco # 71727. I guess I got lucky.
For the top hose you just need to measure length, go to parts house and look for a flex/corrugated hose that has the right size ends on it. That one is the easy one!
