Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (baldeagle, CuzzFuzz, Bill Marlow), 33 guests, and 1 robot.
Topics128,003
Posts1,055,245
Members48,418
#653109 06/08/2010 12:10 AM
Has anyone ever used Nason 2k urethane paint to paint the frame of a truck? Just wondering if its worth the money i paid for it. I used the Nason Chasis Black and didnt like it and i hope this is better. Also do i need to prime the frame first? I will be using phospheric acid to prep the metal first and it is down to bare metal. The guy at the paint shop said it would be fine. any ideas?
gumbi #653150 06/08/2010 3:16 AM
I painted mine with Rustolium gloss black... no primer, painless, inexpensive and simple. I'm using the Nason 2k stuff for the body parts.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #653178 06/08/2010 4:39 AM
Gumbi - Just curious, what didn't you like about the Nason? I'm looking at getting a gallon for my 3800.
aggie jon #653359 06/08/2010 11:29 PM
The Nason Chasis Black didn't seem to dry hard enough. I did half the frame and all of the rear suspension and axle with it and i looks good but it didn't seem to dry hard enough. I Set some things on the frame a week after i painted it and when i picked them up it seemed to stick and pull paint off. This is the pre-mixed stuff and i used rustoleum primer underneath it. I was very disapointed with the outcome of that paint. After i saw this and started looking for something else to go to i noticed a lot of bad reviews on the pre-mixed nason as well. Its a lot cheaper but i wouldn't recommend it. The urethane is more expensive but is supposed to be more durable.
gumbi #653725 06/10/2010 5:49 AM
So does anybody think it would be better to throw donwn a primer first. would the Rustoleum primer be good enough to do the job?
gumbi #654227 06/12/2010 12:07 PM
I believe some stuff doesn't need primer. I don't prime a frame and I don't prime a tractor other than the sheet metal.
Why bother with the primer, put two coats of paint on.
The factory didn't prime the frame first and I don't find any primer under the tractor paint.
I'm not saying there is no use for primers, only that some times I don't bother with it.
Primers that seal or lock in rust are good, but sometimes I feel I can get to carried away with this idea of making something in-destructible.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
