0 members (),
58
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Has anyone ever used Nason 2k urethane paint to paint the frame of a truck? Just wondering if its worth the money i paid for it. I used the Nason Chasis Black and didnt like it and i hope this is better. Also do i need to prime the frame first? I will be using phospheric acid to prep the metal first and it is down to bare metal. The guy at the paint shop said it would be fine. any ideas? | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I painted mine with Rustolium gloss black... no primer, painless, inexpensive and simple. I'm using the Nason 2k stuff for the body parts. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Gumbi - Just curious, what didn't you like about the Nason? I'm looking at getting a gallon for my 3800. | | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | The Nason Chasis Black didn't seem to dry hard enough. I did half the frame and all of the rear suspension and axle with it and i looks good but it didn't seem to dry hard enough. I Set some things on the frame a week after i painted it and when i picked them up it seemed to stick and pull paint off. This is the pre-mixed stuff and i used rustoleum primer underneath it. I was very disapointed with the outcome of that paint. After i saw this and started looking for something else to go to i noticed a lot of bad reviews on the pre-mixed nason as well. Its a lot cheaper but i wouldn't recommend it. The urethane is more expensive but is supposed to be more durable. | | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | So does anybody think it would be better to throw donwn a primer first. would the Rustoleum primer be good enough to do the job? | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I believe some stuff doesn't need primer. I don't prime a frame and I don't prime a tractor other than the sheet metal. Why bother with the primer, put two coats of paint on.
The factory didn't prime the frame first and I don't find any primer under the tractor paint.
I'm not saying there is no use for primers, only that some times I don't bother with it.
Primers that seal or lock in rust are good, but sometimes I feel I can get to carried away with this idea of making something in-destructible. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
