0 members (), 83 guests, and 3 robots.
Topics128,081
Posts1,056,318
Members48,442
What is the specifications on the 216 Thriftmaster oil capacity in quarts (without an external oil filter)
Best Regards
Will
I'm not sure Limo but the oil should come to the full mark regardless if filter or not. I would put in 4 guarts and see where it comes to on the stick. If its a quart low add one. If you add a filter then put in 5 quarts and then start it up. After it runs a little then check it. The thing to remember is it needs to be on FULL with or with out the filter.
I think that the capacity is 5 quarts w/o filter, 6 quarts with filter.
Bill Burmeister
Use 5 quarts on a 216 without an external oil filter.
Regards,
Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
OK, I must have a non correct dipstick of the incorrect length or the dipstick tube has been altered, I have added 6 quarts and still no sign of oil on the dipstick.
Best Regards
Will
Can someone out there who owns a 216 give me the correct measurements for the length of the dipstick tube (from the block to the opening at the top) and the length of the dipstick bayonet from the tip to the "stop" on the handle. I believe mine is of the wrong length, I cannot read any oil on the stick after adding 6 quarts to the crankcase. I do not want to over fill and run this engine for fear of blowing out the seals.
Best Regards
Will
Dipstick tube is 6 inches.
Dipstick length, from tip to the stop is 14.75 inches.
Regards,
Greg
Thank You very much! The one on my engine does not match those measurements, obviously someone has made a substitution over the years.
Best Regards
Will
should be plenty of those around. If you have problems let me know. I just pulled a 52 216 that I am not going to use!
Ex Hall Monitor
Ex Hall Monitor
The specs for my 38 are 5.5 qts dry & 5 qts to refill after an oil change.
