2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 33 | | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Don't know about that one. You put the same link up twice.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | P1010176.jpg looks like an SM420 transmission (here is another photo) transmission - the standard GM 4-speed for many years. The rear housing-cover was different in different years and for different sizes of trucks. The brake on the back is a drive-shaft (propeller shaft) parking brake, used on many large trucks. What year/size truck do you want to use it in (and, open or enclosed drive shaft)?
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Does that transmission have an extra lever on the shifter? It looks like a 4 speed non synchro transmission that predates the sm420, commonly referred to as a crash box. I need more pictures to be able to tell. | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I'm with BigDaddy on this one, it's a Pre 1948 transmission. If you would post the id numbers on the side of the transmission case, someone here could probably interpret it for you. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I posted a few photo-links in my post above - it sure looks likes it's an SM420. Can anyone provide a photo-link for a side-view of an earlier "crash box" 4-speed? This is supposedly a photo of the earlier transmission (note the reverse-lever near the top of the shift-lever/handle) Here is the location of the SM420's date casting-code. H3061 H = Aug 30 = 30th day 61 =1961 This code is near the top of the driver's side of the case (I cannot make out the code shown in archie's photo above). The size and shapes of code letter/numbers are different over different SM420 years. | | | | | Joined: May 2010 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 33 | | | | | | Joined: May 2010 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 33 | yes it has a split shifter? bar at the top. the best number i could get off the picture with enhancement was 103882 gm 591907 i will take a rubbing of this unit tommarrow | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | I think the one with the brake on the back is a SM-420, but I did not see the shifter very well. The other one, more rusty without the brake does have the little rod beside the shift rod so I agree it is pre-48.
Professional Novice
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "It has a split shifter"
Which "IT"?
The one with the brake on the back looks different from the one in the truck? What year truck has the one mounted in it (the one with the split shifter)?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I agree with Frank.
And, the covers are different on the two transmissions that I am able to view (the link-s do not work well).
| | | | | Joined: May 2010 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 33 | boy can i get it wrong the brown little one has the split shifter not the grey one with the brake. sorry after 14 hours straight things tend to blur. | | | | | Joined: May 2010 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 33 | thank you all for the information. now i will have too find a use for these two, as they do not fit with the 292 the previous owner put into the panel. Even if they fit to the motor i like a 5 speed. | | |
