4 members (Gdads51, dt235sd, baldeagle, Mike Roache), 171 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#65140 08/31/2006 10:42 PM
Junior Member
Junior Member
I have 2 1939 Chevy Dump trucks and the engine numbers (stamped on a lip directly behind the distribter)are HAM78782 and JEAI056812 but all the info i have found says the numbers should be soumthing like K 2689129 any one have any ideas?
thanks
Steve B
#65141 09/01/2006 12:21 AM
Ex Hall Monitor
Ex Hall Monitor
I believe 1939 & up used the number in front of the distributer by the fuel pump as the engine number.
I think that those engines may be replacements.
The 216 and 235 engines from the forties and early fifties had a three or four letter prefix and the serials were just aft of the dizzy.
That would make your HAM engine a 1950 built in Tonawanda that was originally used in a car, and your JEA is -- I'm 90% sure on this -- a 1951 babbit pounding 235 built in Flint. Assuming, of course, that the "I" is a "1".
