1 members (Rnl364),
104
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65140 08/31/2006 10:42 PM | Joined: Aug 2006 Posts: 6 Junior Member | | Junior Member Joined: Aug 2006 Posts: 6 | I have 2 1939 Chevy Dump trucks and the engine numbers (stamped on a lip directly behind the distribter)are HAM78782 and JEAI056812 but all the info i have found says the numbers should be soumthing like K 2689129 any one have any ideas?
thanks Steve B | | |
#65141 09/01/2006 12:21 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I believe 1939 & up used the number in front of the distributer by the fuel pump as the engine number.
#65142 09/01/2006 3:10 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I think that those engines may be replacements.
The 216 and 235 engines from the forties and early fifties had a three or four letter prefix and the serials were just aft of the dizzy.
That would make your HAM engine a 1950 built in Tonawanda that was originally used in a car, and your JEA is -- I'm 90% sure on this -- a 1951 babbit pounding 235 built in Flint. Assuming, of course, that the "I" is a "1". | | |
