0 members (),
83
Mod | | | Forums66 Topics128,194 Posts1,057,261 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 110 | I need to remove the door on my truck to complete the paintwork on my cab; however, I need some help with the removal process. My doors are nicely aligned, they close with one finger push...pure luck, nothing I did....but now I need to remove them.
Should I unbolt them from the door bolts or take them off from the hinges....or it doesn't even matter????
Thank you very much in advance....would love to save the aligment of them. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | drill you a hole and stick you a roll pin in it so that when you put the door back on you can align it right where it is.....or just drill the holes and use them for lineup...... or use a sharp scratch awl and scribe a mark you can see when you put them back on. If they close thet good you are a lucky man....when/if you put new weatherstripping on the doors be sure to get the good stuff that will "give" a little bit or they may not close tight for a while....you may have to push on the door a little to close it after the weatherstripping.  | | | | | Joined: Nov 2009 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 110 | Thank you that actually worked. At first I couldn't pictured it but once I got my hands on it, it was easy.
Very greatful, thank you | | |
