3 members (JeepJoker, Bill Hanlon, Guitplayer), 72 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
#65075 08/30/2006 8:20 PM
Jed
Offline
I just received word from a mechanic that was looking at why my 1994 F-250 (7.5 litre V-8) wouldn't start.
He's telling me that with dual tanks, I have to have gas in both tanks, or the truck won't start and run. (Apparently, my father-in-law ran the back tank dry when he borrowed it.)
Now I may be thinking old school, prior to all of this computerized junk they use these days, but this just isn't computing with my brain.
Why would the truck care whether or not one tank has fuel if you're trying to run the truck off of the other tank and it's full?
Anyone out there know anything about this topic?
#65076 08/30/2006 8:44 PM
Ex Hall Monitor
Ex Hall Monitor
Beats me. You might try posting your question in the Froid truck news group (alt.trucks.ford). Someone there has probably run across that problem before.
#65077 08/30/2006 9:28 PM
Should be a switch on the dash. If one tank is dry, the other will provide fuel. If it is a definite fuel problem, and neither tank supplies fuel when switched on the dash, I would suspect the switch, power to the switch and / or the tank selector valve. A bad selector valve could also not provide the proper power to the proper pump. Along the way could be relays, fusible links, etc. Start at one end and work towards the other.
Short version: your truck won't care if one tank is dry.
#65078 08/30/2006 11:05 PM
My uncle had a frieght company and each truck had dual tanks. He told me if it ever starts to die, meaning run out of gas, while driving, switch the tanks as quick as possible or you won't be able to switch them without adding gas to the empty tank. I think the valve hangs up with fluid on one side and air on the other. Don't know for sure, but this urban legend is true,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#65079 08/30/2006 11:11 PM
Jed
Offline
48bigtrucks,
That's quite possibly the answer.
If not, if at least sounds like a reasonable explaination.
Thanks for taking the time to answer.
#65080 08/31/2006 5:43 AM
Jed
Offline
Scott (48bigtrucks)
Went and had a face to face conversation with the mechanic. What you described is exactly what he told me happened.
Sure surprised me. Never would have thought that could happen.
#65081 08/31/2006 6:44 PM
I'm glad she's up and running again,
Scott
Scott Ward
1 1950 3100
1 1963 K20 (454)
1 1964 C10 (350)
#65082 08/31/2006 9:27 PM
Shouldn't be a problem by 1994. I'd replace the valve as it is weak. Furture breakdowns will be coming for sure if you don't.
