2 members (GRNHydra, Rnl364),
74
Mod | | | Forums66 Topics128,064 Posts1,055,859 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64997 08/29/2006 4:59 AM | Joined: Mar 2006 Posts: 29 Apprentice | | Apprentice Joined: Mar 2006 Posts: 29 | My 65 C10 is losing its 3 speed standard and gaining a TH350. The old speedometer cable is too short. Is it difficult to replace? Would a standard speedometer cable for TH350 from lokar be long enough? Thanks.
Also, it is getting a new transmission fluid cooler. My friends tell me I should run it inline with the radiator. Their logic behind this is it will occasionally get cold enough for the fluid to be too cold to allow the tranny to shift properly. The radiator will help warm the fluid they say. It might get to the teens once every few years here in Texas. Although it will freeze several times. Is this important? | | |
#64998 08/29/2006 6:01 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Speedometer cables are available in different lengths from the parts store. If you want a Lokar one, bend over.
The trans cooler question is one everyone will have a different opinion on. Here's mine. In our climate I don't think it makes much difference. I'd just let it warm a little if it's below freezing before driving. I do that anyway to get the heater going. Then take it easy 'til the tranny warms. | | |
#64999 08/30/2006 1:49 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The OEMs mount their tranny coolers in front of the rad, so that they get the air directly into them. Also tranny fluid is pretty thin, I wouldn't worry too much about it freezing.
Bill Burmeister | | |
#65000 08/30/2006 2:56 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Fluid to fluid heat transfer is better than just fluid to air. I would run it in series with the radiator and not by-pass it, Scott | | |
#65001 08/30/2006 6:18 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Take both ends of your speedo cables to your favorite parts store and have them match the ends and provide you with the length you need. It worked for me at NAPA. Always ask the oldest guy there for assist. | | |
#65002 08/31/2006 3:06 PM | Joined: Mar 2006 Posts: 29 Apprentice | | Apprentice Joined: Mar 2006 Posts: 29 | | | |
