1 members (BC59), 67 guests, and 4 robots.
Topics128,179
Posts1,057,157
Members48,464
I know it was originally finished with linseed oil and lamp black but how?
Do you mix lamp black with linseed oil and brush, dip or spray it on?
Do you use boiled linseed oil?
Assuming you mix the two, is there any ratio suggested that will yield original results?
I'm already familiar with the several different newer ways to paint them black but I'm more interested in duplicating the original finish... if possible.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I would "assume" that you would apply the black and then the linseed.
ALWAYS use boiled linseed, the raw stuff never dries, will be gummy forever .... I'd try various ways on sample pieces, like Builder sez, likely burnishing the wood with the lamp black lightly first, then paint with the linseed - try some black into some linseed to see how well it'll mix and disperse, might tend to settle fast
Woody,
Keep us informed (with photos) as you progress.
In an attempt to match what I had read but had never seen (linseed oil and lamp black; or, coal tar and linseed oil) I colored one set of bed wood using MinWax Ebony Stain and followed with satin Marine Spar varnish.
I'd like to get it a little darker - this time, I might look for an aniline dye (coal-tar-based dye - black nigrosine).
J. E. Moser's Lamp Black - aniline dye
(this one is not for water-based delivery - I will check about adding it to a marine spar (satin) varnish.
Thanks for the links Tim, there's a Woodworkers Supply in town or I can order on line. Can't see why you can't just mix it with the Linseed Oil and brush it on but I'll definitely experiment until I get what I want.
This part of the project is still a long way off but you know me... I'll have plenty of in-progress photos when I get to that part.
Woody
Door Art Collection
Here is a link to an artist source for lamp black pigment. It also has information on lamp black. I would just mix it with the Linseed Oil and brush it on. http://www.naturalpigments.com/detail.asp?PRODUCT_ID=480-50S
