1 members (2-Ton),
167
Mod | | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Is there an advantage to one over the other? I am running a 350 SBC in a '57 3100 as a cruiser that ends up sitting still for extended periods of time due to traffic [Woodward Dream Cruise]. Have not had any issues so far, but the orginal radiator is on its last leg with a missing over flow tube, and what appear to be small deposits on some of the vains of the radiator that I assume indicates microscopic leaks? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | original is fine - weeping can be fixed, might just need the tanks resoldered, and the overflow is easy to replace - check a rad shop, should be cheaper to rebuild than buy new .... if yer sittin still for extended periods, save some gas, shut it off  Bill | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Aluminum is cheaper to make, cheaper to ship, weighs less (but most of the weight is water, so the difference isn't that much). Copper cools better. Your choice. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I have had customs made in both Copper or Aluminum - it is really a preference. you have to go to a good radiator shop. I can hook you up with my guy in Green Bay if you want - does great work, good prices.
I personally like Aluminum
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I was in the market for a replacement and was considering the aluminum until I came across an original one on Ebay that had been quad cored then the owner sold the truck. He paid well over three hundred to have the work done but I got it for $87. From what I've learned is that the original units work very well if it's in good condition and will also cool a small block with no problems.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Thanks guys! Sounds like I need to make a visit to a couple radiator places and see what they say. Should I pull the one I have and take with me? I live near Detroit, so you would think the Motor City should have a few qualified places.... | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yeah, around here if you drag it to a shop they'll test it in the dunk tank so you can see the bubbles, makes it easy for them to decide if it's worth just overhauling or it needs a recore
Bill | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | A leak test only shows integrity. It may have been badly repaired in the past, with tubes crimped shut, full of debris, etc. I think there's a flow rate test (how much volume passes in X seconds), but even that doesn't guarantee the surface condition of the interior - where the heat transfers from the liquid to the tube wall. Sometimes the choice comes down to: it is cheaper to do it right (new rad), or do it twice (repair, install, fail, repeat)? | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I have the original 216 in my '53 3100 and need a radiator....would the aluminum do fine for just a weekend driver? | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | eightfan, either aluminum or copper would be fine
| | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | | | | | | Joined: Dec 2004 Posts: 23 New Guy | | New Guy Joined: Dec 2004 Posts: 23 | I know when I looked at rebuilding my orginal radiator, it was going to cost me as much to re-do it as it cost to purchase a Walker copper radiator. | | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | I replaced my recored original radiator this last fall. It was recored back in 2000 and every year I would have to pull it out and reseal the top tank. It had very thin brass tanks that flexed each time it heated up. It would take about a year to cack the solder joint. Counting the first rebuild, and one repair, I could have bought a new one. The new one is aluminum and works great. It holds 14psi just fine, truck runs cooler then ever, and I don't have to worry about pulling it back out! Its a real treat pulling a radiator in a '37, so I hope this was the last time.
I bought a Afco brand radiator. One other thing, since I had to reroute the lower hose, the whole coolant system holds 1 gallon more then the old system did, I guess the longer hose and thick core is where its all at.
Joe | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....shop wanted 542 to repair..bought a new for $250 a year ago.
I will not argue one way or the other as it depends on conditions and other variable. Engine, size, ect ect.
But when I ran my original in my 37 with a 350 set up it ran warm fairly qucik. My biggest problem was the engine sitting low in the frame compared to the radiator position. Well last year I had a leak on the top tank seam and put an aluminum in it. Any time I cut it off and walk in front of the truck it seems like there is twice the "heat" being expelled from the aluminum than with the old copper radiator.. which was a NEW core when I built it. So, take your choice?? I just know what I "feel".
I am currently putting a 305 in my 52 Panel and the engine sits "low" in it to. However, I have a new 4 row copper radiator for it and will see how it cools...but all in all that will not be apples to apples as the amount of air going in is different than the 37.... and the 37 has a hotter performace engine.
This is just my opinons and what I have observed. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I had mine recored locally with a 4 pass copper core w/original upper tank and frame for about 1/2 what i had priced a same capacity aftermarket aluminum for. And since it was built using the original mounts and upper tank, it fit perfectly and still looks original. Cools very well. Plus I supported a local business and it's USA built!
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | So the expectation should be that since the existing radiator does not profusely leak it can be recored, and that recoring should be less expensive than what it would be to purchase a new one? What do I look for when talking recore? I like the idea of supporting a local if not US business as I am sure that most replacement ones are from country C?!!! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... recore is when they use your top and bottom tank and the "core" is what goes between them. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Here's a link to an aluminum one on Ebay. This one has a built in trans cooler for the same price and is advertised to handle up to 1000 hp.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I was in the market for a replacement and was considering the aluminum until I came across an original one on Ebay that had been quad cored then the owner sold the truck. He paid well over three hundred to have the work done but I got it for $87. Well, maybe I spoke too soon. The seller has yet to ship the radiator and has stopped communicating. If you ever come across cdunk907 selling anything avoid him like the plague! I canceled my payment and bought an aluminum replacement. | | | | | Joined: May 2010 Posts: 4 New Guy | | New Guy Joined: May 2010 Posts: 4 | As rightly said, both of them are fine. The point to keep in mind is that the conductivity of the solder between the pipes and fins in a copper radiator is much less than in an aluminum radiator. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Got my 4 core aluminum from Jegs at a good price. 3 yrs of service and still happy. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | the conductivity of the solder between the pipes and fins in a copper radiator is much less
Why? | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Monster Cooling sells a two row replacement unit for $169 & a three row for $219.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I don't think there is much difference between alum and copper. However the copper mfgs I know about are all oldtime manufacturers selling a proven product (if new) as apposed to those that make the alum. The important issue to me would be the quality of the construction of the alum rad not should I get, alum or copper. As I didn't know the quality of any of the alum mfgs I picked copper and bought from an old line rad mfg in Memphis, Walker Rads.
~Jim
| | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I took my original '56 radiator in to be eyeballed and it was flowing horrible, had a few weeping leaks, and overall looked sad. The cores were sets of plates lined up like an accordian, the edges are fluxed, then the whole deal is dipped in molten solder. Essentialy, once they get old and start to come apart they are trash.
I had mine recored with a single pass 3-tube copper core with vented fins that masively increased the cooling effectivity. It's rated to handle a 500hp SBC, and I can attest that when I was movin full loads (10K+ for a GVW of 21K) up a VERY steep hill all day my 270's temp never got any higher than it does when I'm just tooling around town. Finding a good rad shop that does top work can be a challenge, but you can have an original looking rad that performs like a custom unit for about the same price or less. Research your local shops, THEN go see the ones with good repuations. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | find out who the race crowd uses. They will tell you who the best local shop is
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | One thing that I see that has not been addressed here is be sure to use Distilled Water in Aluminum Radiators and the right type of Anti Freeze. I was told by the radiator manufacture to use a water wetter too.
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | A wetting agent for water is simply soap. Don't use too much or you'll be foaming from the mouth. lol
~Jim
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I noticed there is a place in Brighton, MI (south 1st street) that does this type of work.
I'm from Brighton. It was cool to see this company
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I couldn't find the monster cooling radiator for $167/$219.
Is there a link?
| | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Silly question... are radiators on Task Force interchangeable with same year passenger cars? | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I went ahead with the aluminum unit I mentioned previously from Monster Cooling.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | To cool my 30 over 400,i have a big block pontiac 455 in my 55-2 it cools it if you don't set to long in one place run's 180 other wise but i really don't like the way it fits ..all most cooked the 400 with the stock one i got out of a caprice ...know a guy runing a 400 in his 56 with a big block Chevelle that fits much better ,,but you can't find one around here in the junkyard .......guess it's best to just step up for a new one ...to do what ever it need's to do to get job done... | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | So I guess my question was not just silly about interchanging, but just down right dumb! Oh well!! | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | You are asking for information and/or advice. This is a good place for that. We all have opinions to provide.
I disagree with your statement about silly or dumb questions. Never feel that way.
| | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | OK guys, need some collective advice here.....
I was getting ready to drain my radiator and take it in to see what could be done as far as recoring, when a buddy stopped by and proclaimed that all I have is 'external electrolysis' and that there is no need to spend the money on any repair. Claims if I just pour some vinegar on the areas it will take the deposits off and I will be good to go. His says these are just a result of mineral deposits or whatever on the outside.... I have a couple pics posted on my link.
What should I do?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | mmm I think yer bud is blowin smoke - it's possible the 'staining' is from over flows, but most likely from leaks under pressure, I'd take it to the shop and have them pressure test it and get their advice .... and skip the vinegar, it's extremely corrosive, it's not "CLR kitchen cleaner" - you could do as well to clean it off with a scrub brush and garden hose, but I'd count on it coming back in time
Bill | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Ok, so I before I pulled the radiator I called two places in the Metro Detroit area to get an idea of what a recore would cost...WOW! $475 and $530. Oh and estimates on when they could have it done are 8 and 6 weeks respectively.
So, now I am thinking might at well just buy a new one and here is where I need some advice. What vedors are reputable? Will one from Jim Carter/ LMC/ Classic parts all be the same quality? I dont really like the look of the Aluminum that I have seen, and even those that are specific to my truck seem pricey. I dont want to skimp but this truck will never travel this far from home but will spend considerable time at low speed/idle. Thanks!
| | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Just installed a new aluminum radiator. $185 for a two row unit with A/T cooler and shipping. http://stores.ebay.com/PERFORMANCE-COOLINGGreat radiator, fast shipping, and an excellent price. The upper hose connection was larger than my old one, but the parts store had a hose no problem. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I bought 2 row aluminum from Jegs, summit has the same thing. price at both`$169 works great. | | |
