1 members (baldeagle),
53
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I looked at a truck today, a 1500,4wd, with a V-6. I like the truck, but I have no knowledge or experience with a V-6.
Anybody got anything to say about them?
What about enough power to pull a boat and trailer??
Maintenance/Repair issues?
Anything good or bad?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | | | | | | Joined: Mar 2010 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 76 | What kinda six? Guessin a 4.3. If so, thats not a bad motor. Its like having a 350 less two cylinders. Not to sure if I'd pull anything to heavy with it. On the other hand I had a 84 s10 with the 2.8 and pulled a 18.5' Lund boat. Take it or leave it. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | It is in a 96 Chevy. I think it is a 4.3.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have a 4.3 in a 2WD Chevy 1/2 ton. I love the engine. I'm sure it can handle a 18.5 boat OK. I pull a flatbed trailer with a small tractor and loader. It is not fast, but works out pretty good. I made a 800 mile trip with my truck loaded down with about 800-900+ lbs and it traveled just fine. I was skeptical of V6s up until the time I got this truck. I noticed that it stays in overdrive much better than my 5.3 1/2 ton although there is no comparison in power. I am certainly a fan of the GM 4.3 now. If you end up driving with small loads, or a town driver, it will work out great. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 4.3 is a good engine, other than being a known oil leaker. If you're really wanting a 4x4, though, you might want to look into a V8 rather than the V6, especially if you plan on towing. Seems the V8 and V6 are very close on feul mileage in the 4x4s.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Thanks everyone, I will just have to drive it and see if I like it.
