8 members (Hotrod Lincoln, baldeagle, Otto Skorzeny, 1955 1 Series, Rusty Rod, dt235sd, Woogeroo, 1 invisible), 359 guests, and 4 robots.
Topics128,165
Posts1,057,087
Members48,463
JFG
Offline
I need to align my AD hood. The Stovebolt tutorial specifies that the left fender-to-firewall brace rod should be 27" and the right 27 1/4".
But which is left and right? Is that when standing in front looking at them, or as if sitting in cab?
Perhaps 'Driver's Side Length' and 'Passenger's Side Length' would be clearer.
Anyway, one of my rods is slighltly bent, so it's not obvious which way is correct.
Anyone out there who's done this, can you set me straight?
Thanks.
discussing vehicles, left is always the drivers side regardless of where you're standing or sitting .... unless you're in a country where the drivers side is the wrong side wink
They are referenced when standing from the front as shown in figure 7 here:
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1105.htm
You Tube
JFG
Offline
Thank you! I printed that procedure out.
See what I mean by confusion? Already got two completely different answers!
John.
JFG
Offline
PS- anyone know what size wrench fits those square nuts holding the hinges to the body?
Thanks.
Those square nuts are welded in place and you shouldn't need to wrench on them. The bolts come from inside the cab and they are 9/16"
Quote
quoting Squeeze: ..unless you're in a country where the drivers side is the wrong side
Wouldn't that be the right side
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
