| | | Forums66 Topics128,162 Posts1,057,058 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 33 New Guy | | New Guy Joined: Jan 2010 Posts: 33 | I need to align my AD hood. The Stovebolt tutorial specifies that the left fender-to-firewall brace rod should be 27" and the right 27 1/4". But which is left and right? Is that when standing in front looking at them, or as if sitting in cab? Perhaps 'Driver's Side Length' and 'Passenger's Side Length' would be clearer. Anyway, one of my rods is slighltly bent, so it's not obvious which way is correct. Anyone out there who's done this, can you set me straight? Thanks. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | discussing vehicles, left is always the drivers side regardless of where you're standing or sitting .... unless you're in a country where the drivers side is the wrong side  Bill | | | | | Joined: Jan 2010 Posts: 33 New Guy | | New Guy Joined: Jan 2010 Posts: 33 | Thank you! I printed that procedure out.
See what I mean by confusion? Already got two completely different answers!
John. | | | | | Joined: Jan 2010 Posts: 33 New Guy | | New Guy Joined: Jan 2010 Posts: 33 | PS- anyone know what size wrench fits those square nuts holding the hinges to the body?
Thanks. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Those square nuts are welded in place and you shouldn't need to wrench on them. The bolts come from inside the cab and they are 9/16" quoting Squeeze: ..unless you're in a country where the drivers side is the wrong side Wouldn't that be the right side | | |
