| | | Forums66 Topics128,181 Posts1,057,189 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Last night I was working on elongating the U-Bolt holes on my 1/2 axle so that it would fit into my 1 ton springs. Well I picked up a tapered stone bit from home depot and all it did was shrink and never even bit into the metal making it bigger. I was using a drill rather than a die grinder since I do not own one. What can I use in order to open up that hole? Would a dremel be better to use and what type of bit. Obviously the stone one did nothing, it was a gray stone, I have seen red ones and white ones, but this is an area which I know nothing about.
I tried the drill bit method, nothing. The only thing that some what worked was my torch but it made a rough mess that the stone could not even clean up.
Any advice would be great. Thanks
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | My first choice would be a milling machine and the appropriate size end mill. Second choice is what they sometimes call a "West Virginia milling machine" also known as a file, a rat tail file in this case. I'd be quite scared of using the torch to cut a front axle if I then planned to use the axle.  Grigg | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Although I will agree a mill would be the best choice, a drill can accomplish this task if you keep the rpms down. When you say elongating, you don't mean enlarging, correct? You are trying to make the holes oval so the narrower/wider u bolts will fit. How much do you need? 1/4? 3/8? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Go get a cheap (Harbor Freight) die grinder, a metal cutting bur, a long sleeved shirt and safety glasses and go to town, Scott | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | west virginia milling machine- that's funny. i will have to remember that one. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You'll have a difficult time using a drill bit to move a hole if it still mostly overlaps the original. In a rigid setup like a milling machine it sometimes works if the drill is short/stiff, but freehand will be quite difficult if it even works. That's why my first choice would be a milling machine with end mill.
Grigg | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Maybe I'm missing some details here, but is there a reason you're trying to use a 1/2 ton axle on a 1-ton truck? Trying to mix/match parts like that seems like a frustrating procedure at best, and possibly deadly dangerous. I'd reccomend using the right part for the job, rather than trying to force something to fit that's obviously not suited for the application. Jerry
| | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Well it is no longer a 1 ton truck it is now a 1/2 ton sized truck. I have already chopped 21in out of the frame and removed all of the normal 1 ton equipment and putting a 1/2 ton front end on it has been done before. It was done by elongating the bolt holes and putting the u-bolts through it. That is the reason why I am doing what I am doing. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Can I be your life insurance beneficiary? Jerry
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | west virginia milling machine- that's funny. i will have to remember that one. I'll be using mine today to elongate some hinge bolt holes.......  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Just so you know, in place of "West Virginia" you can substitute any state or country which suffers from a worse stereotype than your home state or country. | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Back to the comments about what I am doing, Jerry why is what I am doing that dangerous? I have been asking about this for over a year and nobody has said that it cannot be done. They have been very supportive about it. I thought hot rodding was creating something that you want using what means that you have. I have no money so I cannot replace it with a front clip or a mustang II setup, so alternatively I have selected to use the technology that existed in the 50s and copy it. The holes for the U-bolts are shy by 1/4in the entire size of the pad is the same as it was on the 1 ton. Could I replace the springs and put on the 1/2ton ones sure, but why I already have springs that are good. To this point I do not see anything wrong with what has been done is being done. This isn't my first rod and it won't be my last. Granted I do not have a machine shop in my yard, I have the tools of a mechanic. | | | | | Joined: Feb 2000 Posts: 5,237 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,237 | Changing the spring would do more good then just fitting right. The ride quality will vastly improve going from a 1 ton spring to a half ton. You might find the half tons are still to stiff and will need to soften them up some more.
I can see your problem, on one hand you have to open up the axle holes wider, on the other you have to change springs and hangers. The axle seems like the logical choice, but in the end, its still going to be a 1 ton with a 1/2 to load limit.
I would really look into the spring change, I think you will like it better in the end.
If you still want the axle holes opened up, go get a carbide bur (rotary file) and chuck in your electric drill and have at it. It won't take long, just be sure to wear safety glasses.
Joe | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'm not a big fan of the approach you've taken on the 1 ton demoted to 1/2 ton thing, but that's just my opinion. However elongating the U-bolt holes 1/4" with a file should be just fine, provided you use some good hardened washers and heavy nuts like they'll sell you when you buy your new U-bolts.
If you've used a torch then depending on what was done I'd probably look for another axle.
Grigg | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Actually I was trying it to one hole and when I started to do it, the acetylene ran out so it did not even cut into it. Plus I talked to a shop this morning and they said that even if you did cut it it would have only impacted the metal within a 1/16 of what you hit and I know that I will remove more than that for the u bolts. When I have money I hope to replace the front end completely with a mustang ii setup, but for now it is to get it on the road to tool around.
As far as the 1 ton weight goes I will never carry anything in this again anyway. I am not worried about it, more just a once a month driver than a daily driver. | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Also I was planning on using all the nuts and washers that the 1 Ton had on it. They are in great shape. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It's standard practice and highly recommended to replace spring/axle U-bolts and hardware whenever they are removed, for safety's sake they are not considered reusable. http://www.eatonsprings.com/atqReinstallingUBolts.htmlAny spring shop can make them for you if you take an old one in or have good measurements, they are not expensive. Grigg | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Interesting read, I will have to find a spring shop, but good to know. | | |
