1 members (klhansen), 149 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#642035 04/30/2010 3:09 AM
I have an old 56 chevy and something is slowly draining the battery. I can't figure it out. I have to disconnect the battery when I am not driving it.
Does anyone know of an old timer or someone reputable and reasonably priced who could diagnose and fix it? Also need a rear seal changed, as I am leaking a little oil.
The truck is located in the Adirondacks of NY and am willing to take it somewhere in the Northeast.
Thanks!
If you wanted to tackle the electrical problem yourself, you could try pulling the fuses from the fuse block. Connect your voltmeter to the battery and replace the fuses one at a time until you find the one draining the system. There are a lot of smart guys on here that could probably help you figure it out.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thanks, I will try that.
