| | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 35 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 35 | I have an old 56 chevy and something is slowly draining the battery. I can't figure it out. I have to disconnect the battery when I am not driving it.
Does anyone know of an old timer or someone reputable and reasonably priced who could diagnose and fix it? Also need a rear seal changed, as I am leaking a little oil.
The truck is located in the Adirondacks of NY and am willing to take it somewhere in the Northeast.
Thanks!
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | If you wanted to tackle the electrical problem yourself, you could try pulling the fuses from the fuse block. Connect your voltmeter to the battery and replace the fuses one at a time until you find the one draining the system. There are a lot of smart guys on here that could probably help you figure it out. | | | | | Joined: Aug 2009 Posts: 35 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 35 | | | |
