| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Howdy folks.
I was wondering if any of you have installed or had installed a trailer hitch receiver on your 1964-1966 chevy c10 trucks?
If so, what brand/type/model did you use and how do you like it?
I am researching around for information.
Thanks.
-W
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | All of them are good in the Class III catagory which is all you'd put on a C10. All truck Equipment shops carry them and UHaul always has a good selection tho' you find a better price online. Brands really don't mean much on these light duty hitches. I've put many brands on in my shop ..never had any problems. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i made my own for my c20 and c10. the one i made for my c20 is real heavy duty. i used heavy channel that surrounds the frame. i can't remember the overall cost, but it was cheaper than a hitch. bought a heavy receiver tube from a trailer supply.
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Mine's a Reese. Bolted right on, works good.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Apr 2008 Posts: 95 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 95 | I looked at a bunch and decided on Reese (class 3). They feature nice heavy quality and better appearance than most others. I bought a universal fit (adjustable width) and did some minor modification. This voided any warranty, but I don't care, as there is no way it's going to fail. Once I got the width adjusted just right with the bolts provided, I welded it solid and took out the bolts for a cleaner look. Most of it fits real tight tucked behind my 65 suburban bumper, with only the receiver showing. Total cost was about $125. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i bent down a aftermarket factory made hitch on my 66 c20 years ago pulling a bobcat on a trailer. it's a scary thing. most people prob don't load them down, and on a c10 it would prob fishtail down the road if it was loaded too heavy. yes, it was overloaded on tonge weight quite a bit, though. that's why i went all out on the one on my 64 c20 now. i pull a lot of heavy stuff and i don't want to worry about it. the one i made for my 63 stepside is a lot lighter but i won't be doing any heavy towing with it. just maybe my alum enclosed trailer or a smaller one. | | |
