2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
I need help again. Ever since my truck has been in my possession, it has not had a master cylinder. I have one now and just finished up the pedals & brackets where it mounts. Problem?
I have no idea how the brake pedal and the master cylinder link up.
Can someone send me a photo of theirs so I can figure this puzzle out? I'm obviously missing something but I don't know what.
Thanks!
Tim
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
What size?
IIRC, 3100 and 3600 on up were different animals.
On the 3600 and larger, there is a rod that goes back behind the MC, connects to a pivoting crosspiece, which is connected to the MC plunger.
You stomp on the brakes, the rod moves forward, the crosspiece pivots, which drives the plunger in.
I don't have a camera handy right now, otherwise I'd take a picture.
this is a 1/2ton truck....
Tim Sheridan
Pedal bracket will be bolted to the trans. and bellhousing. The master will bolt to that bracket. The pushrod for the master will have a small clevis looking end on it that will hook right to the lower end of the brake pedal. Do you have the pushrod?
To be long remembered as he's cruising in
The Passing Lane
Quote
Thanks Barry! I knew it had to be pretty simple thing. I was "missing" the clevis looking end: at least I thought I was. I was taking out the garbage tonight and was thinking about your post and looking at the pedal bracket sitting on my bench when a light bulb went on!!!! I remembered I had an old box of misc. parts that came with the truck so I went digging and who'd a thunk? There it was: a "clevis lookin' thing" It fits and works like a charm.
Here's a photo so nobody else ever has to ask this silly question!
Photo of Master Cylindar to Pedal linkage - AKA "the Missing Link"
Thanks again!
Tim
Tim Sheridan
