9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55),
156
0
Mod | | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 14 'Bolter | | 'Bolter Joined: Sep 2000 Posts: 14 | Here's a tip to make your cabinet work a bit better. I use dry play sand and even with my large compressor the gun would not work properly. The siphon tube just wouldn't pick up the sand consistently. I added some talcum power to the media, mixed it well and now the cabinet works great. John Milford, MI | | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Sounds like a good idea John, Can you tell me what the best ratio of play sand to talcum powder you have used for the best results? It may even save wear on the tip of the gun? Dale | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I use glass beads, not sand. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..... if you have a blasting cabinet you will find out no single media will do everything. I like the glass beads for the finish it leaves and for rods/pistons ect. But for the heavy rust stuff I use "mostly" the fine sand. It comes Medium, fine, Xfine. I also have a bag of the Black Beauty as well as a 5 gal bucket of Plastic media. Most blasting cabinets have a nice "drop" under them to change media easily and I take advantage of it.
In my experience I can buy regular blasting sand at the local concrete place that is less money than the play sand!! Plus, the blasting sand is "sized" and works well. Here I just paid $3.28 per 50lb bag for my choice of sand.
The ceramic nozzle are LOTS better than steel and the carbide are really nice. You get what you pay for here.
The cabinet blaster is one of my best investments. I use it a lot.... as well as my friends!! | | | | | Joined: Sep 2000 Posts: 14 'Bolter | | 'Bolter Joined: Sep 2000 Posts: 14 | I drained the sand out of it, and it flowed through my fingers reasonably well. I added talcum powder mixed it by hand and the difference was amazing. The powder came in a 22 oz plastic bottle, I probably added 3-4 oz to 30lbs of sand. The easier it flows the easier it is for the siphon tube to pick it up and pull it through the gun. I'm guessing this would work with any media and either a stand alone siphon blaster or pressure blaster. John Milford, MI | | |
