4 members (2-Ton, Ponchogl, Robert Crandall, 1 invisible), 89 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
I am trying to remove the windshield in 52 AD truck, and thought of removing the frame inside the cab. Some screws are lockedup. But basic question, do I really need to remove the frame to remove the windshield or can I get away by not doing that. Doing a full restore
Ganesh
Ganesh, from what I gather you are referring to what's known as Garnish mouldings.
They are purely cosmetic.
If you are doing a full restoration,surely you would want to remove them?
There maybe underlying rust issues at the lower windshield openings.
To re-install your windshields you will have to remove the garnishes anyway.
More pix on Flickr.
Thanks for that information, thatz exactly what I was looking for because I have to fight with old screws. I will only if I have to
Ganesh
Sooner or latter You're going to have to remove a ton of old rusty screws and bolts so You might as well get used to it ,it's a job You learn to live with .After Your truck is all done and it's setting there it will be well worth it .
Pete
AN IMPACT SCREWDRIVER tool is a must have when working on these old trucks.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I have that one, Well I think I passed the part of removing old screws, bolts etc. This is my last set of screws to remove otherwise everything I wanted is off.............. On my truck everything is off just frame and cab sitting. Rust and undercoating remaining to clean.
Thanks guys
Ganesh
smokey truck, when you pull the moulding off be sure to note the location of some clips that are fitted in the back of the piece of moulding.... there is also some little wire spring looking things that go behind the moulding where the defroster vent is. I think those are to keep you from squeezing the moulding together when handling it. You will see them... and then undertand!
Thanks for that info, I appreciate
Ganesh
