| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63672 07/31/2006 5:19 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | My trans (46 3spd) has started to make some unusual noises. I know that these old transmissions tend to make a lot of noise but this is something new. It's making a moaning noise when I decelerate. It stops if I push in the clutch. I have checked the fulid level and everything else seems to be working perfectly. Is this the trans or maybe the U-joint. I'm not sure what a bad U-joint sounds like. What should I check? Is this going to damage the trans? Thanks George p.s. This trans has been rebuilt, new bearings and every thing. All the gears looked good when I put it back together. | | |
#63673 07/31/2006 9:46 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | | | |
#63674 07/31/2006 9:57 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it does it or is worse in the lower gears You probably have a bearing bad in the trans. If it does it in high gear I would take a look at the rear end. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63675 08/01/2006 3:10 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Is it quieter in 3rd gear than in the other gears? Scott | | |
#63676 08/01/2006 3:54 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I'm pretty sure it's not the rear end. It makes noise in all gears when I let off the gas. Sounds about the same in all gears. Hopefully it's not a bad bearing. I would hate to rebuild that thing again. Any more ideas? | | |
#63677 08/01/2006 4:42 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | With a bad release bearing you should feel some vibration thru the clutch pedal. How did the countershaft look? The shaft acts as the "inner race" and excessive clearance could do it. Did you replace all the pins?
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
