2 members (Gray_Ghost, 50Chevy3100), 71 guests, and 1 robot.
Topics128,056
Posts1,055,800
#63672 07/31/2006 5:19 PM
My trans (46 3spd) has started to make some unusual noises. I know that these old transmissions tend to make a lot of noise but this is something new. It's making a moaning noise when I decelerate. It stops if I push in the clutch. I have checked the fulid level and everything else seems to be working perfectly.
Is this the trans or maybe the U-joint. I'm not sure what a bad U-joint sounds like. What should I check? Is this going to damage the trans?
Thanks George
p.s. This trans has been rebuilt, new bearings and every thing. All the gears looked good when I put it back together.
#63673 07/31/2006 9:46 PM
Release bearing?
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#63674 07/31/2006 9:57 PM
Riding in the Passing Lane
If it does it or is worse in the lower gears You probably have a bearing bad in the trans. If it does it in high gear I would take a look at the rear end.
1972 Chevy c10 Cheyenne Super
#63675 08/01/2006 3:10 AM
Is it quieter in 3rd gear than in the other gears?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#63676 08/01/2006 3:54 PM
I'm pretty sure it's not the rear end. It makes noise in all gears when I let off the gas. Sounds about the same in all gears.
Hopefully it's not a bad bearing. I would hate to rebuild that thing again.
Any more ideas?
#63677 08/01/2006 4:42 PM
With a bad release bearing you should feel some vibration thru the clutch pedal. How did the countershaft look? The shaft acts as the "inner race" and excessive clearance could do it. Did you replace all the pins?
Curt B.
You Tube
