5 members (Bucker, 55shaker, 2-Ton, TUTS 59, 1 invisible), 158 guests, and 2 robots.
Topics128,192
Posts1,057,351
Members48,469
#63515 07/27/2006 8:26 PM
I am looking into buying a Buick 350, Does any one know a lot about these motors?
It actually in a 69 Jeep Gladiator, The owner had an adapter plate made and put on a Quadra jet carb.
Any info would be great.
#63516 07/27/2006 10:28 PM
Riding in the Passing Lane
Great engines. They produce good power & strong torque. They weigh less than a small block Chev. & are very rugged. The only drawback is there is not much speed equipment available. The only aluminum intake I could find for the one in my skylark is Poston. It runs close to $300.
1972 Chevy c10 Cheyenne Super
#63517 07/27/2006 10:56 PM
You'll have to use a BOP bolt pattern trans/bellhousing as it is different from Chevy engines. Any tranny from a Buick/Olds/Pontiac V-8 or Buick rear drive V-6 will work. Wrenchbender's right, not much speed parts, SOME parts will interchange from the V-6, though. Mainly front components like water pump and cam drive.
Bill Burmeister
#63518 07/28/2006 1:00 AM
www.v8buick.com
Is your place for info on Buick engines.
Dave
66 GMC- father /son project with the "GMC KID"
36 Chevy PU- 4x4 lifetime project
64 Skylark- wife says its hers
#63519 07/28/2006 3:31 AM
I think they have an external oil pump which is driven off of the front of the crankshaft. That would be their weak link I beleive. They're wider and heavier than a small block and more costly to rod. If you're dead set on using Buick, go with the 455, it's externally identical to the 350 but a whole lot more cubes,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#63520 07/28/2006 3:00 PM
Its actually in a 69 Jeep Gladiator truck that I was pondering on purchasing.
It’s a running and registered project for $1200. The guy says it runs great but it has a valve sticking when it warms up. He called it a "Dauntless" Buick 350
I wouldn’t put a Buick motor in my bolt unless it was a 455. But my bolt is keeping its 235 until it dies.
#63521 07/28/2006 8:35 PM
Those are good motors, mostly. I wouldn't be shy. They make a whole lot more torque than an SBC.
It would have been the original motor in that truck. Jeep used Buick engines from about 1966-72.
I had a CJ-5 with a Buick 225 V6 with a quadrajet manifold. It had enough torque to snap the spider gears in the front differential in low range.
Paint & Body Shop moderator
#63522 07/28/2006 8:52 PM
If you are interested in a Buick 455 I have a neighbor that has one in his garage for $150. (Kansas) It is missing the camshaft. They produce more torque than any other 455 out there. Perfect truck engines.
55 Cabover
#63523 07/28/2006 10:00 PM
The 455 is larger & heavier than the 350.
#63524 07/28/2006 11:46 PM
Seems to me I heard those engines were used in a variety of applications including original Rovers and marine because they were goodies.
#63525 07/29/2006 1:02 AM
Learn something every day. Always thought a 350 Chevy was the same. My 81 Malibu has a 267" as does my 81 Buick Regal. I presume they are the same.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#63526 07/29/2006 3:06 AM
The Rover engine, which is still being produced, is the 215 aluminum Buick engine that was used on '61-'63 Specials, Olds F-85, and Pontiac Tempest. The V-6 was based on this engine as a replacement when GM sold the tooling to Rover. GM then sold the V-6 tooling to Kaiser for use in Jeep products, after tooling up a cast iron V-8 based on the V-6. In the '70s, during the "gas crisis", GM scrambled to get the V-6 tooling back from Jeep, which had been bought out by AMC by then. Unfortunatly, GM ended up retooling the engine, as the original tooling had been filled with concrete and used as filler in a plant floor by AMC. Ironic, aint it. By the way, very little, if any, parts from the Rover engine will work with the 300,340,350 Buick small block. I do beleive that the moderd efi intake will fit on the original 215 though.
The big block Buicks differ from the small block mainly in deck hight and cylider casting thickness. Otherwise they are very similar, unlike other makes small and big blocks.
By the way- oldblu, your Regal has a Chevy engine, the Buick V-8 was dicontinued in '76. For the most part, by the early '80s the small block Chevy had become the standard "corporate" engine in most of GMs products, with the 307" Old hanging on to the late '80s.
Bill Burmeister
#63527 07/29/2006 7:28 AM
Outstanding info. If only my memory wasn't shot I'd know alot of stuff...
#63528 07/29/2006 8:33 AM
....I used ta know all dat stuff... grin
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#63529 07/30/2006 11:46 PM
Longbox 55 thanks. One reason I bought that Buick was because it had the same engine as my Malibu, which just goes and goes and goes. Very high mileage on it now, near half a million kilometers.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#63530 07/31/2006 12:20 AM
Quote
Small addition here, the Buick version of this engine had very different heads, the traditional (at that time) 'nailhead design. Easily identified by the vertical valve covers. The piston were also different because of the head design.. You can put the Olds pistons in a Buick and get 11.5 compression. Nice back then, but not on todays gas! The Tempest used the Buick version.
The v6 was offered as the base engine (except for Pontiac, who used a 1/2 a 389 V8 slant 4) with the aluminum v8 an option. The v6 was always cast iron though.
The later version of the v6 was even fire, the basis for the GM corporate 3.8 engine. The early ones were odd fire. The cranks were just 3/4 of a v8 with the 90 degree throws.'
#63531 07/31/2006 12:24 AM
Quote
They do have an eternal oil pump in the front cover. It is driven by the cam like most all v type engines of the day. Not a weak point at all. As a matter of fact it makes a pump or relief valve upgrade easier.
If this is a nail head design, I think you will find the weight to be very similar to a small block, maybe a little lighter, width about the same but a touch longer.
Scott
