Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
2 members (Truckrolet, klhansen), 494 guests, and 1 robot.
Topics126,777
Posts1,039,268
Members48,100
Most Online2,175
Jul 21st, 2025
ok gents
where can i send my steering column/box to get rebuilt.
yes i know i could exch and buy a rebuilt one but mine is painted to match the cab interior.
so
i'd like to keep it that way
any ideas who / where???
Jim & Caroline
Rebuild it yourself Jim. Taint all that much to it and you know you'll take better care of the paint job than some guy in Hoboken.
Here a few pics of the process in this Steering album, might give you some ideas. http://www.pbase.com/dennygraham/steering&page=1
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Riding in the Passing Lane
Pretty basic mechanics to do it yourself. Don't take the ball nut apart though.
1972 Chevy c10 Cheyenne Super
I have to agree with Denny. I rebuilt the upper and lower boxes, I even took the ball nut apart to check the races, and bearings. I was fortunate as everything was only slightly worn. I repacked everything, and now the old girl shifts as smooth as can be.
I had no problem rebuilding mine including the nut. Actually all it neaded was a good cleaning and a new output shaft seal.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Once again, taint all that much to them, even the ball nut.
http://www.pbase.com/dennygraham/image/123311869/large
http://www.pbase.com/dennygraham/image/123312827/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
You really can't do it wrong, there is no timing involved or strange operations. If you put all the pieces back in that came out, it will work. Adustment are pretty easy once you understand what they do.
Joe
It is possible to assemble the ball nut/sector shaft one tooth out of position either way and more than once someone has asked on here what they did wrong.
You Tube
thanks gents
I've looked at the pics denny and as usual you do some mighty fine work. nice vote of confidence guys.
hope i don't need those shims as my southbend took a crap on me and no $$ to get her fixed now
thanks again everyone, i'll be back asking questions from you all here in short order
jim
Jim & Caroline
I agree. Do it yourself. Just be careful to not loose any of the balls in the sleeves. Count them when you take the two sleeves apart. That is most important.
Dennis
again
thanks guys
Jim & Caroline
Here are detailed instructions, courtesy of The Old Car Manual Project:
http://chevy.oldcarmanualproject.com/booklets/5220mtsindex.htm
Finally '54
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.064s Queries: 14 (0.061s) Memory: 0.6486 MB (Peak: 0.7377 MB) Data Comp: Zlib Server Time: 2025-09-22 05:59:08 UTC
Valid HTML 5 and Valid CSS
