| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,714 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,714 | My engine, once it's warm and has run awhile, will diesel after I shut it off. What causes this and how do I fix it?
And for all you comedians out there, we're talking a gas burner, not the Dodgebolt (which, having a Cummins, is SUPPOSED to diesel...) :p
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The first thing most commonly checked will be the timing. I have found over the years that setting it to "spec" doesn't always work due to wear. I usually play around and try advance or retard until I found what works best and still not hesitate or balk out on the road. I'm sure others will suggest bad fuel, incorrectly adjusted valves, actual engine temp, even the type of plugs and the list goes on. Usually the culprit will be in the timing! I know we have a scholar or two here which will tell us all about pre-ignition so lets have it folks  | | | | | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | The only time that this has hapened to me, it was a vacuum leak at the carb. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Try richening up the curb idle a little so the combustion doesn't run so hot, and try a step colder spark plug.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | In my experience, the two most common causes are high idle speed and high water temp.
I would first lower the idle to the recommended speed or even 50rpm lower. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It,s usually caused by fast idle speed &/or Vacuum leak. Be shure an auto matic choke is opening all the way 0r a fast idle cam sticking. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | You didn't mention WHICH engine you're working on, but almost all dieseling is a function of too-high idle speed. One sneaky trick the manufacturers tried in the mid-70's when they raised idle speeds to lower emissions was to put a solenoid-type throttle stop on the carburetor linkage. "Curb idle" was set with the solenoid turned on, which was attached to ignition switch voltage, and "Slow idle" was set with the regular throttle stop screw, with the solenoid disconnected. They were about 100 RPM different. When the ignition was shut off, the throttle position dropped to the lower speed setting, effectively strangling the engine. You can also shut the engine off with the auto trans in gear, or leave a standard trans vehicle in gear, and let the clutch out as you kill the ignition. Either one will create enough load on the engine to retard the tendency to diesel. Jerry
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I concur with the high idle being the culpret. And as HotRod has stated you can play with your idle settings if you prefer a higher idle. My old 79 Monte had an A/C idle up solenoid that mounted to the carb and "bumped" the idle when the air was on. You could adapt one of these to set your base idle and when the key goes off it would lower the idle too low to diesel on. You probably need a 12 volt system though, Scott | | | | | Joined: Nov 2003 Posts: 53 Member | | Member Joined: Nov 2003 Posts: 53 | Lowering the idle speed is sometimes effective in masking the problem, but idle speed is not the cause. Something hot in the combustion chamber is causing the mixture to ignite in the absence of spark. Look for a lean mixture (vacuum leak or carb settings), marginal cooling system, carbon deposits, or too hot a plug. We run old 6 cylinder gas gensets that shut off very politely from 1800 RPM by simply killing the ignition. | | |
#6347 12/06/2004 10:58 PM | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | pre-ignition or over run.Is this ride driven everyday??.Sounds like carbon build up on the heads or pistons from a sunday driver.Take her out on the highway for a real good runnnnn.Pedal to the metal.If you don't want to run her hard.This is from the old school.Remove the air cleaner with the engine running,reving.pour about a quart of water slowly into the carb, reving the carb.Don't let it stall.This will remove the carbon from the heads.If you look at the tailpipe you'll see pieces of carbon on the ground.Check timming,adjust carb mixture and chock ,idle.Just remember tap water is cheep
dan-pa
| | | | | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | JEEZO-PEEZO !
Don't _EVER_ ' pour ' water into an intake as it doesn't compress and can easily crack pistons , bend rods and crack heads too ~ use a trigger sprayer and carefully mist the water in as it only takes a tiny bit to blast the built up carbon off the combustion chamber .
You must have the engine fully warmed up and revved as fast as you can stand it whilst doing this , be aware black hot carbon bits _will_ come flying out the exhaust so don't be backed up to the white garage door when you do this .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#6349 12/07/2004 10:05 AM | Joined: Jul 2003 Posts: 33 Apprentice | | Apprentice Joined: Jul 2003 Posts: 33 | when i have had this problem I usually take off the vacum hose from the distributor and put it in a bottle of water while the engine is running at about 2000 rpm. Using the vacum hose gives you control of the amount of water put in the engine so you dont damage anything. I have tried this on a lot of engines and never had any problems.  | | |
